Nog måste det här va rätt udda Pontiacs...
Postat: 09 apr 2016 00:28
1970 Magnum 400
In the fall of 1969 as the 1970 Pontiac models were introduced, Bill Knafel decided to introduce his own inexpensive, lightweight performance car. He was aware of the success of the Plymouth "Roadrunner", so he felt that by ordering the right combinations of options, he could market a successful performance car. He named it "Magnum 400" and sold about 50 that year. It started out as a Tempest coupe ordered with the 400 4BBL engine, Rally II wheels, the 1969 Judge stripe, and other choices of options to suit the customer's taste, such as 4 speed or turbohydramatic transmission, Safe-T-Track differential, and performance rear end ratios.
Åsså den här... (trodde inte dom fanns 1970, bara senare...då T-37)
•Pontiac big block 350 engine (L30). The engine produced 255 hp & 355 lb/ft of torque, with the casting #11 heads and Rochester 2bbl carburetor.
•Low-restriction dual exhaust with chrome splitter exhaust tips. (N10)
•Three speed manual heavy duty transmission with Hurst floor shifter. (M13)
• Ride & Handling package. (Y96)(springs, shocks & stabilizer bar)
•Rally II wheels (N98) without chrome beauty rings.
•G70 x 14 white lettered tires
•Hood Locking pins.
•1969 GTO Accent stripes.
•140 MPH speedometer.
•Front fender and trunk lid GT-37 emblems.
•Bench front seat (buckets seats were not a option)
You could order the optional engines.
1.The L65 option engine was a 400 engine with a 2bbl Rochester carburetor and #11 heads rated at 265 hp & 397 lb/ft of torque.
2.The L78 engine was a 400 engine with a 4bbl Quadrajet carburetor and #16 heads rated at 330 hp & 445 lb/ft of torque, with an automatic transmission.
3.The L78 option 400 engine with dual-snorkel air cleaner a manual transmission and #12 heads produced 345 hp & 430 lb/ft of torque. This was the Ram Air III engine with out the hood ram air assembly.
•Hood Locking pins.
